Beiträge von Kollegga
Ich finde Schläuche und Schellen nicht optimal, es sei den Sie kommen vom Hersteller.
Der Wagner EVO LLK hat auch Schläuche und Schellen etc...Wenn Sie nur in ihrem teureren LLK die anderen Schläuche verbauen und das bei dem ETS dann nicht so prall sein soll
Also ist das schonmal kein wirkliches Argument für Wagner sondern eher dagegen o_0 -
Hier noch ein paar Links zum ETS:
http://www.extremeturbosystems…and-335i-Intercooler.html Daten und Graphen zum ETS
http://www.e90post.com/forums/showthread.php?t=567631 beinhaltet die Thematik LLK im Allgemeinenund eine kurze Zusammenfassung zum ETS:The biggest difference like Jeff said is the intercooler design. The average intercooler that is 5.5" tall only has 6-7 charge rows. This gives you a total of 10-12 heat transfer plates. we designed a core that has 10 charge rows giving you 20 heat transfer plates, well 18 since you don't count the very top one and the bottom one. By having the extra heat transfer plates we are able to lower the density of our internal fin pack giving us more air flow, less pressure drop and overall more heat transfer area. The external density of fins is also greater on our core. Another key note is most manufacturers use a /\ style fin on the external side and heat transfer can only take place at the very tip of the fin. We use a TT style fin pack which give us 4x the surface area with the heat transfer plates.
Lots off little things is why our intercooler performs so well in a smaller package.
Und noch eine globale Zusammenfassung zum Thema LLK
To sum this up without being long winded:
- Any upgraded FMIC is better than stock
- Size is not everything
- Meth will actively lower IAT's more than any FMIC
- Core effiency, face size, and end-tank design are all factors in an effective FMIC
- Better end tanks distribute air coming in from the inlet efficiently throughout the intercooler core
- Learn about pressure lossI would highly recommend ETS's 7" core or ER's FMICS (you have to cut a little with ER).
Ich glaub ich muss mein JB4 auchma einbauen...
baut ihr das vorm TÜV wieder aus?
Ist es schlimm, wenn ich den DPFIX drin habe und bisher noch mit der normalen DP fahre?! -
Statt das Spiegelklebeband zu nehmen, würde ich dir zum Tesa Outdoor Montageklebeband raten! Hält auch bombenfest, man kann es aber in einem Stück wieder entfernen!
Das ist echt sehr gut!
Nur beim Montieren aufpassen, dass es direkt an der richtigen Stelle ist
Bisher bis 250 keine Probleme!
