Kann mir bitte jmd. das hier vom Englischen ins Deutsche übersetzen.....check das nicht ganz : (
Dankeschön. ![]()
"VII. ADJUSTING FOR RESPONSE
a. There should not be a need to adjust the Synchronic BOV. However, you are welcome to try the following configurations so long as the result does not produce compressor surge.
i. Vacuum only to Port A (5)
ii. Vacuum only to Port B (6)
iii. Boost only source to Port C (7) (compressor signal or intercooler pipe signal) in combination with Port A, Port B, or Port A + B.
iv. It is not necessary to adjust the pre-load spring (8). It is best for response to leave this as loose as possible. This feature is for future applications. If you choose to adjust the pre-load to change response, clockwise is more preload and counter clockwise is less preload."
