Could you please help. How can I get the old ones (not M) out and put new one in? Is there a trick how to get them out? i don't want to breake something. If you could write in English will be great if not in german.
Thank you.
Thank you.
The easiest way to get them out is when you use plastic wedges (hopefully the right word for this tool) under the old ones (door panels) and a little bit more pressure. The new one can be pressed in the other way round.
Hopefully I could help you.
Regards,
Ox
Pull roughly! You can use a screwdriver and a towel or, which is safer: an assembly wedge.
I tryed one on rear door, but this plastic clips stayed in the car. Probably I have to put them out? How can I get them out? Just pull strong?
You can remove the clips by using a plier.
Yes! Pull Strong ! Use a pliers
do I need than new plastic clips?
thank you all for your help.
Usually not, but be carefull.
No u can use the old ones
they might break so be carefull.
Edit: I´m kinda slow
