1: BMW-Fan87 - OBD Kabel
2: gotcha43 - OBD Wlan
3: Brabender - OBD Wlan oder Kabel ?
4: serkib - OBD Wlan
5: domicreation - OBD Wlan
6: Hyperstripe - OBD Wlan
7: neugierig - OBD Wlan
8: Sinsui - OBD BT
9: funfly123 - OBD BT + OBD Kabel
10: Erem42 - OBD BT
11: pirate-ratz - OBD WLAN
12: xinghui - OBD WLAN
13: Master Chief - OBD Kabel
14: bUll1t_335i_LCI - OBD Kabel
15: NilsN - OBD WLAN
16: djure - OBD BT
17: Budberger - OBD Kabel
18: Jaky - OBD WLAN
19: aschmiddi84 - OBD Kabel
20: Keybreak - OBD BT
21: co2mars - OBD BT
22: RobertSch85 - OBD WLAN
23: eric0815 - OBD BT
24: Mexx82 - OBD BT
25: aoddragon - OBD Kabel
26: BirdOfPrey - OBD BT
27: E90_Racer123 - OBD BT
28: Rob91 - OBD WLAN
29: Zobi - OBD Kabel
30: andrjucha - OBD Kabel
31: Subacromialis - OBD BT
32: MWB - OBD BT
33: Stan - OBD BT
34: rodi6661 - OBD BT
35: JMK - OBD WLAN Adapter fürs iPhone
36: pade - OBD Wlan
37: Osmanfive - OBD BT
38: Fanatic1803 - OBD BT
39: UmmelGummel - OBD BT
40: Kokelpit - OBD BT
41: NeSoBozz - OBD Kabel
42: holger1234 - OBD WLAN (iphone/ipad)
43: T-1311 - OBD BT
44: RS1983 - OBD WLAN iPhone
45: CabRyder - OBD Kabel
46: J0bsti92 - OBD Wlan Adapter(Iphone)
47: okiE90 - OBD WLAN Iphone
48. Domme - OBD Kabel + OBD BT
49. Michel_66 - OBD BT
50. Windorfer - OBD WLAN iPhone
51. easyrider1985- OBD BT
52. Muzl - OBD BT +OBD Kabel (Android)
53. chriscom - OBD BT +OBD Kabel (Android)
54. Jalapenjo - OBD WLAN iPhone + OBD BT (Android)
55. Agent_Engel - OBD Kabel (Android)
56. thaslider - OBD Kabel (Android)
57. Chaser - OBD KABEL (Android)
58. Bas - OBD KABEL (Android)
59. EpSoNic - OBD BT (Android)
60. Snixx - OBD BT (Android)
61. Zap73 - OBD BT (Android)
62. nrgryder - OBD Kabel (Android)
63. W0RSCHD - OBD BT (Android)
64. TeRoX - OBD BT (Android)
65. Sh@rk - OBD BT (Android)
66: e90-lci-325 - OBD WLAN (iPhone)
67: convex - OBD Kabel (Android)
68. JensK - OBD BT + OBD Kabel (Android)
Beiträge von JensK
Warum coddieren? Ich dachte die kann man ein und ausschalten???
Bleibt nicht dauerhaft ausgeschaltet. Beim nächsten Motorstart ist sie wieder automatisch an.
Der rote Knubbel kann ein Anzeichen für eine Alarmanlage sein.
Wenn man eine werksseitige AA hat ist auch immer dieser rote Knubbel dabei.
Andersherum heißt es aber NICHT, daß wenn der Knubbel
vorhanden ist auch tatsächlich eine AA verbaut ist.
Das Blinken der LED im Knubbel kann auch bei NICHT-VORHANDEN-SEIN
einer Alarmanlage codiert werden (meines Wissens)...
Also am besten testen wie in Post 8 beschrieben.
Start/Stop Automatik hat der Wagen.
Die Automatikmodelle haben keine. Die Schalter schon, zumindest die 4-Zyl. Motoren. Aber da auch nur die neueren.Ahh, sehr gute Info. War mir bisher nicht bekannt.
Dann hat Stan ein Automatikgetriebe
... und habe einen automatisch abblendenden Innenspiegel...
Weil Du das hier im Innenspiegel hast, richtig ?
[Blockierte Grafik: http://foto.arcor-online.net/palb/alben/85/1428685/6361613537386337.jpg]
Also Flo, Start/Stop hat Deiner auf jeden Fall. Zumindest ist der OFF-Knopf bei Dir unter dem Klimabedienteil vorhanden.
Sieht man auf dem Innenraumfoto.Ob Alarmanlage vorhanden ist kannst Du leicht testen: Motorhaube entriegeln - aus dem Fahrzeug aussteigen und absperren - paar
Sekunden warten und dann die Motorhaube öffnen - dann sollte er losfiepen.
Ob Kurvenlicht an Bord ist sollte man ebenfalls leicht rausfinden können.
ich habe keine
Aber war schon beim Kauf bekannt.Ich habe nicht mal den Knopf innen wo es man manuell abschalten kann
Super, dann brauchst Du es wenigstens nicht rauscodieren...
Gib deine Fahrgestellnummer mal bei vin Decoder im Internet ein. Dann siehst du die komplette Ausstattung vom FahrzeugGenau!
Hier z.B.
http://www.bmwarchiv.de/vin/bmw-vin-decoder.htmlStan:
Du hast keine Start/Stop-Automatik? Sehr ungewöhnlich.
Hat das BMW wieder abgeschafft bei den neueren Baujahren ??
Nachtrag: ach ich sehe grade - bei mir steht Start/Stop unter SONDERAUSSTATTUNG
Dachte das wäre SERIE... -
langsam wachen se alle auf!
Weiter Jungs die 50 knacken wir noch !!
Man Leute, noch fast 6 Wochen Zeit... GEDULD...
Wer weiß was bis dahin noch alles passieren kann...
Einfacher ist FOLIEREN (lassen) im angebauten Zustand...
